You're pulling 10+ dB out of that at the frequencies where I find the driver isn't happy. So your 100W becomes 10w.
You're pulling 10+ dB out of that at the frequencies where I find the driver isn't happy. So your 100W becomes 10w.Mine are down to 110hz on 100w. But after making cuts and dropping them to match the combined output of my left and right. Who know how much power they are seeing. But at full tilt they have 0 distortion and sound really good. I just took these for @tjk_bail
Raw no filters, then 100-3k LR24db, then EQed at those same crossovers.
Yea, but there's no need for more in that area, its a midrange not a midbass. It's a centre channel. I'm not using it to get low like a midbass. That's volume 15/30 (usable volume) by the time I hit 25 they are screaming loud. 1 GB40 gets the output of my left and right GB25 combined. Now if your trying to overpower them in the bottom octaves of the usable passband of any driver you will introduce distortion. But if your just trying to cover a null and not get crazy midbass out of it the GB40 should do just fine.You're pulling 10+ dB out of that at the frequencies where I find the driver isn't happy. So your 100W becomes 10w.
Thanks for taking the time to post this information !!Mine are down to 110hz on 100w. But after making cuts and dropping them to match the combined output of my left and right. Who know how much power they are seeing. But at full tilt they have 0 distortion and sound really good. I just took these for @tjk_bail
If your footwell 5.25's are covering 50hz to 220hz, then pairing up to your GB25's, what are you GB60's doing ??My GB40s didn’t sound very good when I first installed them because of how they were screwed down into my dashboard.
Pretty much the same thing with my GB25s in the door. I installed them using my factory Toyota steel mounts but, they didn’t sound good at high volume. I then used a thick speaker gasket material & put them in pods & they sound great now!
Pics of GB25 pods & in one picture you can see 1 of the 5.25” subwoofer but, the door is open so you can’t see how close the GB60 actually is.
GB60s are doing 80hz to 220hzIf your footwell 5.25's are covering 50hz to 220hz, then pairing up to your GB25's, what are you GB60's doing ??
Yea I'm sure it is. That speaker is behind my floating head unit pointed directly at the window. I'm actually surprised that's all I have.Thanks for taking the time to post this information !!
By looking at those measurements, I think they look promising for what I have in mind.
Thats a crazy null you got there at 270hz......Prob a cancellation null from windshield.....
wait wait .... your 5.25 subs are playing 50hz to 220hz, and your GB60's are playing 80hz to 220hz....hummm something about that doesn't sound right.. but, hey, if it sounds good ... !!GB60s are doing 80hz to 220hz
As I said before, look up “Cone of Confusion” here on DIYMA.wait wait .... your 5.25 subs are playing 50hz to 220hz, and your GB60's are playing 80hz to 220hz....hummm something about that doesn't sound right.. but, hey, if it sounds good ... !!
I am also doing the cone of confusion with multiple subwoofers stashed around the SUV too.
cone of ConfusionI searched for Cone of Confusion and got 481 results.... can you post the link your talking about here....
So ignoring the 4 nulls you probably won't hear (green trace @175Hz + 205Hz, purple trace @220Hz + 280Hz) what you're left with is a valley that's <= 10dB. Pulling down both sides around the valley should make it look and sound a lot better.I have a huge null at 150 through 270 on Left Mid-base... check out pic below...
More good reading: One of The Reasons Your Midbass is AnemicI searched for Cone of Confusion and got 481 results.... can you post the link your talking about here....
I had my sb acoustics Mnrx12 crossed at 160hz lr4 with no issues and they sounded great doing it. You could consider these for that application at the very least if they don't work for ya you only spent $120 and some fabrication and time 🤷♂️
