1 - 6 of 6 Posts
So I have a stock audio system with a stock HU which I would like to keep. The question is can I use the MS-8 if the amp is built into the HU and my system isn't a premium audio system. Also if my HU only has 4 channels will the MS-8 make a sub channel out of it or what?
the MS8 is a GREAT OEM system integration unit you 'll connect your stock highlevel outs ( IE wires that would normally go to speakers) to the MS8 and then connect its powered out puts to your speakers, very simple ,very very good upgrade.
oops for got to answer the rest of your questions. In short the MS-8 only needs one set of full range inputs to create up to 8 discrete output channels. so yeah you'll get sub, and sides and rear, and center if you want them too...
download the manual and read it! it will answer all of your questions....
but the answer is yes..
1 - 6 of 6 Posts
