I have a set of component at the moment for rear fill. Should I take my Time alignment measurements from the tweeters or midbass? Both off same passive crossover. This is a pick up truck with stock OEM speaker location. Should lower the gain or lower the crossover frequency?
I have a set of component at the moment for rear fill. Should I take my Time alignment measurements from the tweeters or midbass. This is a pick up truck with stock OEM speaker location. Should lower the gain or lower the crossover frequency?
Assuming that they are passive and mounted close together, measure from midway between the two.
