1 - 2 of 2 Posts
hello im looking for a head unit recommendation
my primary source of music will be from an aux-in cable from my phone (galaxy S with voodoo kernel to use the onboard wolfson WM8994)
so SQ coming out of the phone should be pretty good...
my setup:
front stage - hybrid audio stage 4 clarus with passive crossovers
sub - focal 27kx 11"
amp - exile audio xi800.4
I'm aiming for under $200 used, but I'm kind of clueless on what my options are.
If my music is mostly coming from an aux-in cable does the quality of the head unit matter?
I might want to use CDs/usb sticks/sd cards, but not necessary. Are there options besides cd player head units that might be better? I could go possibly higher on the pricetag if there are some strong suggestions.
Thank you all in advance! :)
don't use a head unit. Install a mount for your phone and run a cable to an electronic crossover if you want. I would just run it into the amp and use a jumper RCA if necessary. I would put a volume knob on the RCA's though so you can adjust it quickly and have it mounted in the dash near the phone.
1 - 2 of 2 Posts
