1 - 5 of 5 Posts
I'm having trouble finding this info.
Does anyone know the recommended enclosure volume for an Illusion Audio LM-12 subwoofer?
thx.
thx.
I don't, but I can design a box for you. See the link in my signature.
Well I guess I did not state this, but I don't have T/S parameters either. If I did, then there are many tools to help calculate this.
I will gladly accept T/S parameters for the LM-12 as well.
Any info is appreciated. BTW, I have searched on here as well as the greater web with no specs found. The Illusion Audio website seems to be long gone.
This is all the specs in the catalog I have:
Power Handling: 300W RMS
Sensitivity: 94 dB
Impedance: 4 Ohm
FS: 33 Hz
QTS: .4
Vas: 3.92 Ft3
Not much, but hopefully that helps.
The ND-12 needed about 1.5cf, sealed.
Found this list with a bit of google magic- no idea if it's accurate:
P/N Size VC Type dB W Z Re Le Ce Fs Vas Qms Qes Qts Xmax Cutout
AUDIO HIFI cm mm 2.8V mH F Hz li mm mm
LM-12 32cm 50mm Poly Cone 94 250 4 3.7 .37 27 25 91 .30 ±15. 282
ND-12 32cm 75mm Carb Cone 96 400 4 3.4 1.0 82 26 102 6.2 .28 .26 ±15. 282
1 - 5 of 5 Posts
