I tried using WInisd to model the box for this SI15D2. Stereo Integrity recommends 2CF Sealed.
Should I follow the recommendation? Car is a MK6 GTI Powered at 1000watts. Could use the space for a vented enclosure if it would be better for the system in this car.
THX
SQL- 15
Sealed enclosure: 2.0 ft^3
Vented enclosure: 4.25 ft^3 tuned to 22 Hz. >20 in^2 of port surface area per driver.
Cutout: 352 mm (13.9”)
OD: 392 mm (15.5”)
Mounting Depth: 8.1”
Weight: 28 lbs
Displacement: 0.16 ft^3
System
DSP = Helix HELIX DSP.3S / 8CH / All Active
Drivers
Front
T = AUDISON VOCE AV 1.1 CH 1&2 Amp #1 (Sail panels)
M = Morel Vitus Nano Carbon MM2 2-1/2" CH 1&2 Amp #2 (Flush Dash Mount up at windshield)
MB = Audison Voce AV 6 CH 3&4 Amp #2 (doors / dampened)
Sub
Stereo Integrity SQL 15D2 / in 2CF sealed, CH 7&8
Amps
Amp #1 = Sundown Audio SDX-90.2 [email protected]
Amp #2 = Sundown Audio SFB-1800.5D 5 Channel Class D [email protected] &[email protected]
THX
SQL- 15
- Re: 3.25 Ohms
- Fs: 23.8 Hz
- Qes: 0.45
- Qms: 5.83
- Qts: .42
- Le: 2.0 mH
- Sd: 130.17 in^2
- Vas: 115 Liters
- BL: 20.417
- Mms: 388.55 g
- Cms: 115 uM/N
- Xmax: 28.4 mm one-way via 70% BL. (56 mm total p-p linear excursion)
- SPL: 95 dB (2.83V/1M) – 1 Ohm operation
- Power Handling: 1000 watts RMS
OD: 392 mm (15.5”)
Weight: 28 lbs
System
Drivers
Front
Sub
Amps
