1 - 11 of 11 Posts
· Registered
Looking for the best shallow mount 8" subwoofer out there. Looking to run one or possibly two in a sealed box underneath the rear seat of a 2021 F-150 SuperCab (extended cab, less room than a full crew cab)
I like TIGHT, punchy bass, not woofy overpowering bass.
Sub will be run off a kicker key 500.1 at either 300w @ 2ohms or 500w at 1ohm
I will build the enclosure to ideal cubic foot for the subwoofer but I'd prefer it be as small as possible. Something between .2 and .7 cubic feet or so.
Any thoughts on the kicker L7T-8?
Also, a single is better than two subs for SQ, right?
· Registered
Getting the sound you want is all related to the alignment you get from the enclosure you build.
You need to define the "maximum" mounting depth and budget for this as well.
No, a single is not better than a double for SQ. With 8" Subs you need as many as you can fit for the cone area to get the maximum impact. My son's 2 x 8 (Morel H8.1) in a 1.5 cuft box ported at 38 Hz are very tight on 300W in a Extended Cab 1995 F150 and enough to rattle the mirrors but they have very little output below the tuning point so bass notes that drop in to the 20s are lost. So in reality that's not very SQ worthy since the tuning point is so high.
Are you more interested in low frequency extension or output and what volume level are you trying to achieve?
· Registered
Why an 8 and how shallow is shallow? Do you need a pancake sub, or can you get by with a sub that's just not super deep but still has a standard design?
· Registered
Volume needs to compete with hertz components and coaxials in the doors running at 50w per channel.
In a down-firing box I have 6.5 inches of depth under the rear seat. That's not including thickness of the MDF or the space needed underneath the box for excursion of the sub
· Super Moderator
Message sent...
QUOTE:
Prima sub woofers employ a special cone-dustcap-basket geometry which guarantees large excursion of the mobile group, while keeping the mounting depth to a minimum. The surround and spider have been carefully designed to prevent the “rocking-mode” phenomenon. The cooling circuit has been designed with air vents on the basket underneath the spider, eliminating the need for vents on the bottom-plate. This allows the sub woofer to be mounted close to the back wall of the enclosure, making the most of the reduced mounting depth.
Automotive design Carbon Grey Automotive exterior Rim
· Registered
I have a pair of the 8" version of these in my c4, I'm very pleased with them. They can keep up with a dynaudio 3 way setup. Very good subs for the money IMO.
1 - 11 of 11 Posts
