So I'm reading what I feel or understand to be very contradictory explaination of relays and suppression diodes.
I'm hooking a relay triggered by my dsp's remote out.
Now, the first pic is my relay. It shows anode side (which is described to be the positive side that lets current through) hooked to ground.
And the cathode side (which is described on bcae1 as being negative ground side) hooked to positive.
I want to trigger coil with remote out which will supply 12v to my amps remote inputs.
But if I hook the diode up in picture 1, with positive to 86 as it says on relay, wouldn't that let the collapsing magnetic field spine of voltage go to my dsp remote out and kill it?
I just want to protect my dsp.
