Hi!
I've replaced the Audio 15 in my W447 Mercedes Vito with a Sony xav-ax8050d and am using a CANbus interface.
The factory fitted reverse camera works as designed and the unit switches to the reverse camera when reverse is selected. The original steering lines are still overlaid which was a bit of a bonus!
However every so often when driving the reverse camera flicks on for a second or two and then turns off. Sometimes the video signal is blank but often it shows the reverse image which indicates either the head unit, interface or van computer has triggered the camera to pop out. It seems to happen when changing/selecting the lower gears (I have a manual gearbox).
I have checked the wiring, replaced the interface and also added a diode to the reverse signal in case the head unit was sending out a signal rather than just receiving but still have the problem.
Would appreciate any thoughts/ideas about what might be causing the issue.
Many thanks in advance!
