Looking for some guides help. Have a 2016 GMC Sierra. 3 way active focal running on JL 800. Jl stealth box with two Jl 10 running on Jl 600. Jl fix 86 and Jl TWK 88. My issue is in Room Wizard. I have read all the training and referred to Andy’s approach etc. and try to follow all 24 LR.
Sub-60
Midbass- 80-500
Midrange- 500 - 2400
Tweeters- 2400
If you look at graph, the 1/6 RTA is my right channel... the green is left channel and yellow is curve. My struggle is on the twk 88 i have to lower the levels to -9 and -10 on midbass to get to curve and tweeters -12... I have read and that you should be leveling with gains verse levels on DSP. Is that the case. Wouldn't it be same outcome. Just doing it by level may have a little more noise since gain is higher etc. any advantage or disadvantage? Once I have that piece figure out, how do you guys level sides as I have read different things. I have just looked on RTA and tried to level match each channel side by side to look level on graph. I have also just used a DB meter and set each tweeter and midrange to same DB and tried to get midbass close. but matched both sides and then EQ.. is that correct? Just confused as I read so many things. Also I have been using 1/3 RTA to get to curve. If I use 1/6 or 1/12, I feel I eq a ton more but not sure how to determine which ones to leave alone. I even did Mic in 5 locations and averaged and still confused on what to change and what not to... I can always get to curve and it matches both sides perfectly, but some eq are -12.. Just trying to cut to the chase as this is becoming so very time consuming and I guess want to know in my mind that I am at least doing it correctly and maybe just the crappy song.. have all the test CD' as well and center imagine is good. just when I play music seems shallow and not the power.. when I run without eq the power is awesome but all over the place...
Final question is what is the preferred RTA... I see people say 1/6 or 1/12.. but it i feel I have a millon eq's to adjust verse 1/3. Is spectrum easier to work with and get closer will less EQ... I feel like I understand quite a bit but missing something for sure.. also, so I tried to switch slopes... I am all 24... today switched the sub and midbass to Butterworth 24 and seemed more power but didnt look at RTA... Just struggling as maybe this is too much or what an I missing.
Sub-60
Midbass- 80-500
Tweeters- 2400
