I was wondering anyones thoughts on powering the DIYMA with this amp. Had it for years (i think i bought it in 2002), never used, and was a decent amp for its day... Any idea if I will be sacrificing a lot of SQ by using this amp?
Here are some specs:
100 watts RMS x 2 at 4 ohms
200 watts RMS x 2 at 2 ohms
400 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
50-210 Hz high-pass/low-pass (12 dB/octave) crossovers
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
speaker- and preamp-level inputs
dimensions: 12-13/16"W (8-13/16" without endcaps) x 2-1/2"H x 9-13/16"D
2-year warranty
2-year warranty
