1 - 3 of 3 Posts
I recently bought a Rf Symmetry Epx2 and this doubt come to me.
I have a BLDs of my zapcos amps, I see the DIN conector its the same....but, before I damage something, first asking if someone have experience with this connection...
I believe the cable pinout is the exact same. I used a Rockford/Denon RFX-8250 which had the mini din balanced connectors on the back and ran them direct to the EPX2 Symmetry. The Zapco symbilink uses the same connections from what I understand
The cable should be the same, but as for the conversion I am not 100% sure, since the BLD will be adding voltage, and if the power in the balanced cable is reversed that could mean some fried gear.
I have an original Rockford BLD as well as the Zapco BLDs not sure if there is much difference in the wiring
1 - 3 of 3 Posts
