1 - 13 of 13 Posts
So, I've been a hardcore Rockford fanboy since the late 80's/early 90's, and while I've been using tons of other brands besides RF over the past ~15-20 years, I still lean on their sub amps. Partially due to nostalgia and partially due to my own track-record with them (started with an old “Pre-HD” Punch150, then POWER300, then POWER1000 MOSFET, and kept going from there - Always loved them).
However, I see ARC has some pretty serious offerings with their KC2500.1 which is an Analog switching G design vs the b/d on the Rockford T2500-1bdcp. I’d never heard of ARC before I joined up here a few months ago – but they certainly have my attention with these new amps! ARC’s uber-high-end "SE" amps are a also sight to behold!
I also see that the well-respected designer Robert Zeff came up with the KS2500.1 design - and it is a “Modern” 2012 design (the bdcp's are from 2010 IIRC).
What’s the general consensus on the ARC KC2500.1 vs the T2500-1bdcp? Feature-sets are practically identical and street pricing is neck-and-neck. The ARC seems to be a bit more efficient (210Amps for 2600 Watts), and the ARC seems like a better design from my initial impressions.
The amp will be driving a trio of W12GTI’s @ 1Ohm in a ported enclosure in a 2013 4Runner. Obviously looking for some low-end SQ, and also love to have some serious SPL to back it up (I do like it LOUD and clean when called for!).
Thanks – and Rock On! :cool:
The arc's lower msrp makes it a winner in my book.
Owned a few KS amps and never had any issues. They are well built workhorses and noise free to boot.
So far you guys are swaying me towards the KS2500.1 - And that is what I was actually hoping for :)
Any more persuasion - specifically between the KS2500.1 and the T2500-1bdcp in my specific application?
The one small caveat I'm looking at: I don't plan on going crazy with a 300Amp Alternator (might get the stock one re-wound, but it's 130Amps stock IIRC), but I will run the largest AGM battery I can fit up front (odyssey or kinetik). I don't plan on "dime-ing" either of the two amps (would smoke the subs if I did ;) ). Knowing this, does the bdcp's "Constant Power" function sway anyone's opinions? If anything, I'd figure the bdcp will end up pulling much more current if I do push it hard as the voltage might sag. Where the ARC would simply put out a bit less power w/o exasserbating the amperage draw issue (I'm actually fine with that - should still have headroom if I'm lucky).
I had a RF T20001bd @ 1.5 Ohms and a serious front-stage (JL 450/4) in my '99 Tacoma on a puny 90-Amp factory alternator and a single Odyssey battery up front - never had any battery issues if that gives you an idea of my listening habits for comparison's sake. I only had to replace that stock alternator once in 12 years!
Thanks for the feedback - Keep it coming and persuade me to go with ARC!!! :D
The KS2500.1 is super efficient too.
A little plain or understated to look at, but on the other hand, easy to customize.
Also very easy to strap to another if you want even more power..
LOLZ! I'm hoping I'll have all of the headroom I could ever need with a single KS2500.1 - much less TWO of them :eek: !!!
I do love my SPL, but hopefully the single 2500Watt monster will make me a very happy man. The only amp I own that has equivalent power is the 120VAC Crest CA12 I run in my PA System (1400Watts x2 @ 2 Ohms on four JBL 2241G subs in custom enclosures).
:cool:
I think constant power means fully regulated.
Rockford always has played with words.
The bdcp is regulated for sure - but it also rides the +/- rails dynamically relative to speaker load (dynamically relative to frequency) to get a "constant power" output (with a lower Z the rails will be pulled down some, with a higher Z the rails are brought up some to end up with constant power). Like the JL Slash series does, too, but the JL's regulate over a slightly broader range of impedance loads.
A more standard/basic regulated power supply will keep the rails at a constant voltage which helps against B+ input voltage sag, but will not dynamically adjust the rails as the speaker load changes.
I generally prefer unregulated amps on subs (and less NFB), and while I don't believe the ARC class G can truly be unregulated by the topology's nature, at least it's not riding the rails with speaker load.
I also own a 1500.1bdcp, and I liked the older "non constant power" T20001bd better - even at 1.5 Oms where both amps were roughly equal in output power.
Regardless - the ARC is really looking good. I see WoofersEtc sells them for $889 shipped. The T2500-1bdcp goes for around $850. Neck and neck, but the ARC is floating my boat for the time being...
I'm going to poke around locally and see if anyone carries them in the same price-range, or might have an install with one to audition.
Thanks again for all of the valuable input! Rock on! :cool:
update - I made my decision - The ARC KS2500.1 is on its way to me via Woofersetc ($799 shipped!). It will be a little while until everything is installed, but I'll report back with my impression. :cool:
Don't forget the pics :D
Still waiting for the 4Runner to arrive @ the dealer, but here's a pic of the ever-growing "stash" :D
(4) W12GTi's (two boxed); PHA-H800; INA-W910; RUX-C800 (all boxed)
JL 450/4; JL 300/2; ARC KS2500.1 (still in the plastic!)
Stinger 1/0 OFC Amp Kit + Distribution Block; PAC Steering wheel and Video Bypass adapters; Scosche Radio Mounting Kit
Waiting on: Alpine Rear-View Camera & License Plate mount; Digital Cable for W910
Front Stage (Morel Integra Ovation XO 4" Point Source & Morel ADMW 9's) - plus some sort of 6.5" rear door speakers.
I'm getting pumped!!! However, my wallet is getting DRAINED!!! :D ( :( ) :D
Discussion Starter #12
A few pics!
Alpine H800 DSP ; ARC KS2500.1
JL 300/2 ; JL 450/4
3x W12GTi's - Sealed - 1.3 cu ft each. 1 Ohm net load for the full rated 2848 Watts from the KS2500.1!!! :eek:
So far, so good. I've only auditioned the KS2500.1 for less than an hour earlier today - but I can already tell you it has some pretty big balls! While I can't compare directly to the Rockford BDCP series (still own the 1500.1BDCP, but I don't plan on A/B'ing), I can say I like ARC Audio thus far, and have no regrets on my KS2500.1 purchase. It does seem pretty efficient (as ARC promised)...
Back to work! :cool:
1 - 13 of 13 Posts
