1 - 19 of 19 Posts
Rockford RFX-8240 (Denford - Denon made)
http://www.rockfordfosgate.com/rftech/library/2002/1_Source_Units/MAN4223A_RFX8240-50_Pla_MAN.pdf
Phoenix Gold Xenon x200.
Phoenix Gold Xenon X200.4
Peerless XLS 8" 830491 (x4)
http://www.d-s-t.com.au/data/Peerless/830491.pdf
Rockford RFX-8240
CD transport malfunctioning w/ noisy output when CD playing, mint face no scratches, parts or for repair unless you only listen to FM/AM. Sold As-is
Phoenix Gold Xenon x200.4
Demo/display, mint w/ box and all rubber boots
Peerless XLS 8" (x2)
Brand new, never used/mounted
Rockford RFX-8240 - SOLD
PG Xenon x200.4 - $300 shipped OBO
Peerless XLS 8" (x4 drivers) - All SOLD
Free shipping to the lower 48 states
First to pay will receive the items. If I receive two payments from interested parties, first payment gets the item, the subsequent payment will be refunding ASAP. I will not hold the items for anyone I have not done business with before. I will be happy to answer questions, but that does not mean I am holding the items for you.
I stand behind everything I sell and condition as stated in the thread. Just check out my iTrader and references for feedback :)
Bump for my bud and also one of the most bad ass amps of our time!
hey Corey..glad to see you.
yeah, one bad amp.
Wow, your back!!! Thanks man and I would have to agree regarding the price/performance Class A/B at 200W RMS X 4, triple Darlington output stages, xovers, etc where can you get that for $300???
PMs replied and as requested, here are some pictures of the Denford RFX-8240, as yes those are balanced Symbilink connections ;)
Somebody buy that Denford and send it to Matt R for an upgrade.
I was actually going to do that but honestly just dont have the motivation to do so and went a different route which is why I am selling it ;)
All PMs responded to, hopefully selling soon :D
Discussion Starter #13
Peerless XLS 8" (x4 drivers) - SOLD
Phoenix Gold Xenon x200.4 - $300 w/ free shipping OBO
# 200W x 4 (4-1 ohm stereo)
# 400W x 2 (8-2 ohm bridged)
# Xe.load™: optimized for any impedance load
# Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
# Xe.flow™: variable thermal feedback controlled fans
# Tried and true triple Darlington output stage
# Buffered RCA full range thru output
# Remote Monitoring Display (RMD) port
# Low Pass Level control ready (LPL-44)
# Built-in Crossovers
# Optional Remote Voltage Display
# Optional Remote Low-Pass Level Control
# Variable input sensitivty
# 0 - 18dB Bass Boost at 45Hz
# CEA-2006 Compliant
# Dimensions: 22" L x 10.6" W x 2.5" H
Real world testing by Eric @ soundbuggy.com:
The output voltage of the amp to be 30V prior to clipping. This is most impressive. 30V is good for 225W into 4 ohms, if the current can be sustained. With 10 power supply MOSFETs, it should stay fed so long as 4 ohms is the impedance you use. Xe.load should cut the amp back if lower impedances are used, but keep in mind for "average" use, Xe.load will likely not limit you.
With a 3 ohm set of Boston components, 300W a side is possible!
Discussion Starter #18
BNIB LPL-44 Remote Low-Pass Level Control and BNIB Remote Voltage display (RMD) for free with the PG Xenon X200.4!!!
1 - 19 of 19 Posts
