Hi fellas I have finally gotten the Ok to purchase my equipment. I have always wanted to do a all Alpine build. This is not my first install but it is most extensive install that I have done all at once.
I would like SQ, but at the same time I like loud.
I am going to put 180^3 ft of RAAMat in the car. Seal the doors with FG (if fronts are IB) Can I get a better deal on the Deadener on here? I am going to seal the cabin with lead tape on seams and most of the hardware is going to get some silicone (necessary?). FG will be used for allot of my build and the entire interior will be out of the car.
I have some much needed questions that I have found scattered info on but I would really appreciate some input.
Car; 2007 Civic Si Coupe
HU: Alpine IVA-W205
F/Com: Alpine Type R or Type X ref (6.5)
R/Spk: Alpine type R (if necessary)
Sub: Alpine Type X 12
Amps: Alpine MRP-F300, MRP-M1000
Ok first off is rear fill needed? If it is not I can spend the extra money and get the Type X ref set.
If there is no rear fill can or should I seal the rear deck? Will the bass make it into the cabin ok?
Will the front seats have a full sound to them without rear fill?
Should I mount the tweeters on the A pillar or the door near the driver?
Will the drivers sound better if I make them sealed rather than IB? Also if they are IB it is imperative to seal the front of the door correct?
Is the roof of any importance to deaden? I can if it will be good because the headliner will be out of the car.
What would be the best product for road noise? Is the RAAMat enough?
I really think a sealed enclosure is my best bet in the trunk, but should I do everything I can to point the sub towards the rear?
Are there any differences in sound quality of a inverted mount Sub?
Are Banana clips (if gold plated) going to transfer quality sound into the Sub box?
Oh and I am stumped on a quality brand of wiring. I would prefer not to by monster, but I can’t break the bank at the same time.
Only using 1300 ish watts I am going to run 1/0 to the trunk and use a distribution block to split it to two 4ga.
Is a sleeving material the best way to go, something like Techflex?
Am I doing myself and my budget wrong by using all Alpine products?
HU: Alpine IVA-W205
