I have a Skar Audio RP-2000.1D 2000 watt mono block amp. I have it run to 2 Skar Audio EVL-15 D2 15-inch dual 2-ohm 1250 watt subwoofers. The only way to wire them to this amp is at 2 ohm or 0.5 ohm and the amp it rated at 2000 watts at 1 ohm. At 2 ohm im only getting about 1400 watts so about 700 watts each. My question is can i wire them up at 0.5 ohm and turn the gain down to 2000 watts and run it that way without hurting the amp? I know the equations for tuning the gain to match my subs. I dont want to do that tho i just want to run the amp at its rated 2000 watts or more specifically 2300 watts because that's what it dyno tests at 1 ohm.
