1 - 9 of 9 Posts
Is it ok to Run 6 Ohm Tweeters on a 4 Ohm Amp and if so will it sound ok?
Specs:
JBL BP 80.4 (40w x 4 @ 4 Ohm)
Morel MT-23 Tweeters 6 Ohm / Power Handling 130W
PS, i'm not going for maximum loudness here, just good SQ. ;)
wont make any difference. you will just get slightly less power than the 4ohm rating.
Specs:
You should expect about 30 watts from that amp at 6 ohms.
6Ohm should be about 25% less power than at 4ohm. Not gonna be a problem for you. So like thomas said, ~30watts.
it actually comes out to about 26 watts, but whos counting ;)
1 - 9 of 9 Posts
