I've always set up my amps by the dmm/test tone method, using the rated power of the amp and the calc. on the12volt.
My JL amp is rated at 45w x6 at 4ohms on 12v. But the birthsheet for it says 79w x6 at 4ohm on 12v. I usually set it by the voltage chart in the manual, but would it be alright if I set the amp for say 55 or 60w per channel? According to the birthsheet the THD isn't much higher at 79w
