Hi all. I'm following this guide to set my gains with a multimeter:
learn.sonicelectronix.com
I'm setting 2 amps. Below is what I think I should be doing, but I would like help confirming.
Sub Amp (model noted):
Per the instructions, I think I should be doing:
Mid/High Amp (model noted):
Per the instructions, because the amp has 2 gain knobs, I'm a little lost. Is this correct?:
Hope I've explained this clearly.
Really appreciate any help with this.
How to Adjust Amplifier Gains Using a Digital Multi-Meter - Sonic Electronix Learning Center and Blog
The gain adjustment control on an amplifier is one of the most misunderstood concepts in the car audio world. Setting this correctly is extremely important, unless you want to damage all of your audio gear.
- 1200 watts @ 1 ohm (at the amp)
- 1200 x 1 = 1200
- Square Root of 1200 = Set gain for 36.64 Volts
- To get that, put (+) and (-) of multimeter as shown above: (+) on (+) terminal of left channel, (-) on (-) terminal of right channel.
- Is this correct?
- 100 watts @ 4 ohms per channel (treated like 2 separate amps due to 2 separate gain knobs)
- 100 x 4 = 400
- Square root of 400 = Set the 2 gain knobs for 20 Volts each
- Do I put the (+) and (-) of the multimeter into the same (+) and (-) pair on one of the amp channels?
- Ex: for the left channel in the picture, I would put them into that farthest left (+) and the (-) right next to it?
- Then repeat for the right channel?
