1 - 20 of 36 Posts
Moderator
Thanks to Adam at Madisound for helping me out with this.
Alright, I just wrapped up testing on the SB Acoustics 17NRXC35-4, 6.5" midwoofer driver.
SB Acoustics SB17NRXC35-4, 6.5" Woofer: Madisound Speaker Store
The data is attached in PDF form.
I ran this particular test 6 times total. The results were always the same.
Displacement Limits (based on 82%Bl, 75%Cms, etc):
X Bl @ Bl min=82% 4.4 mm
X C @ C min=75% 1.9 mm
X L @ Z max=10 % >4.5 mm
X d @ d2=10% 26.2 mm
Thanks for the test. I have been looking into the 8'' version, this will give me an idea what to expect versus the data supplied with it.
Thanks for the test!
Can see that full copper sleeve on the motor working well.
Those drivers have a world class motor attached to a half-assed cone.
Moderator
Discussion Starter · #10 ·
If you guys thought the mag coned Seas Excel was a bastard to work with, the paper coned SBs are worse.
From Zaph data:
FR shows some bad breakup starting at 4khz. Real bad.
Distortion wise it looks good above 100hz. When you get to 1.5k it gets rough.
Bandpasing them between 60-2khz seems more nominal. As a pure midbass they'd probably be good. For $140/pair it's not bad to try.
In a car, off axis and steep slopes would be a must given how rough those things get...and 2k is about all I would try to get out of it.
As a midbass only, they might be pretty good. Meniscus seems to like them...or they make huge profit on them one, cause every time I have asked about midbasses...we really like the SB 7 line.
I will say this... 3 of us were impressed by how smooth they were running with no crossover up top today. maybe my ears just can't hear it... what should I listen for in the break up?
we are running them out to 4k
We are going to spend a bunch of time today listening to them... Is this an acceptable place to give my $0.02 on how they sound?
Thanks for the data on these woofers. I have a pair I'll be installing in my MS6 sometime soon.
Another forward offset... This is beginning to bug me. Where is Dan Wiggins when you need him ;)
Erin are you running any break in on the drivers you are testing? While I have not been a big believer that break in makes a night and day difference I do believe that it makes a little difference (I know, very subjective - I believe the suspension loosens up a bit). I wonder if these drivers with a forward offset would show up centered after extended usage?
Why does it always seem to be an outward bias. If these were random assembly errors I would expect to see some inward variations as well. I don't know but I am beginning to have a hard time believing this is just an assembly error (and I darn sure dont want to admit Cajunner was right and this is an actual design feature :) ).
1 - 20 of 36 Posts
