I built my last box with 3/4 MDF and used Titebond II glue at all joints followed by silicone at the inside seams. I used a brad nailer to hold it together until the glue dried. I've not had any trouble with it so far. I had one guy ask me why I didn't use screws. In my mind, the glue will create a strong bond and be stronger than the material itself. This is evident in some videos where the glued joint was placed under stress and the material failed before the glue joint.
This brings me to my question. Do you really need to use screws in the joints? Is there a point at which the enclosure's size could determine whether screws are necessary? I would think that larger enclosures with greater surface area on the panels would benefit from them and smaller (~1 cu ft) could be fine without.
What are your thoughts on this subject?
