1 - 1 of 1 Posts
SEAS 6.5 INCH PERFORMANCE 2 WAY SET
Condition of all items: GREAT CONDITION. PLAYED VERY LITTLE
Total Price: : $450.00
BUYER PAYS SHIPPING AT $15 THROUGH USPS WITH TRACKING.
Specs:
The PW165/1 woofers
Glass fi brecone, stiff low loss rubber surround carefully matched to each other result in smooth frequency and clear precise reproduction of critical midrange area. Relatively large voice coil diameter results in high power handling capacity. The magnetic system with T-shaped cross section of pole piece gives low modulation distortion. Bullet shaped phase plug reduces compression due to temperature variations in the voice coil and avoids resonance that would occur in the volume between dust cap and pole piece and increase the power handling capacity. Extremely stiff and stable injection moulded metal basket keeps critical compression in alignment .
*Nominal Impedance: 4 ohm
*Frequency Range: 50-30000hz
*Short term power handling: 100w
*Long term power: 250watt
*Sensitivity: 90.0db
*Voice Coil Diameter: 39mm
*Voice Coil Height: 12mm
*Air gap height: 6mm
*Linear Coil Travel: 6mm
*Max Coil Travel: 19mm
*Magnet Gap Flux Density: 0.88T
*Magnet Weight: 0.42 kg
*Total weight: 1.70 kg
*Voice Coil Resistance: 3.3 ohm
*Voice Coil Inductance: 0.78 mh
*Force Factor: 6.0N/A
*Free Air Resonance: 64 hz
*Moving Mass: 16.9g
*Air Load Mass: 0.82g
*Suspension Compliance: 0.4 mm
*Suspension Mechanical Resistance: 1.3
*Piston Area: 126 cm
*VAS: 8 litres
*QMS: 5.49
*QES: 0.65
*QTS: 0.58
Tweeter PT27F
Diaphram is formed from pre coated fabric material careful matching fabric and coating results in smooth frequency response throughout audible frequency range. Wide roll surround together with double chamber magnet system result in a low fundamental frequency compact dual chamber neodymium magnet. The voice coil is immersed in magnetic fluid allowing high power handling capacity and simplified crossover design.
*Nominal Impedance: 6 ohm
*Frequency Range: 2500-30000 hz
*Short term power handling: 180w
*Long term power handling: 80w
*Sensitivity: 89.5 db
*Voice coil diameter: 26mm
*Voice coil height: 1.5mm
*Air gap height: 2mm
*Linear coil travel: 0.5mm
*Voice coil resistance: 4.9 ohm
*Voice coil inductance: 0.05mh
*Force Factor: 1.9 n/a
*Free Air Resonance: 1000hz
*Moving mass: 0.23g
*Effective piston area: 7.5 cm
*Magnetic Gap flux density: 2.0
*Magnet weight: 0.01 kg
*total weight: 0.15 kg
1 - 1 of 1 Posts
