1 - 20 of 20 Posts
I'm going to do a 3 way setup now that I'm going to be using a DRZ9255. I have 160 watts rms @ 4 ohms x 2 to work with. And a max mounting depth of 3.65-3.75" So these are the two that I've narrowed it down to.
Seas L22RX4X/P
and
Peerless Exclusive 830884
Can someone tell me which one will be more efficient, they are rated at 1W/1m 86 dB for the Seas and 2.83V/1m 89.3 dB for the Peerless.
In other words, which will work better with the power that I have, or should I not even be worrying about that?
These are only going to be playing from as low as they can go(hopefully 40 hz) to about 165-200hz.
I'm leaning to the Peerless because of the truncated frame which would be easier for fitting them, but is there any reasons why the Seas would be a better choice given my power ratings?
Are there any differences in their sound charachteristics?
Hopefully someone has had a chance to listen to both of these. :D
Thanks for any help.
Oh Ok, one more reason for me to pick the Peerless :D
Anything else you notice that shows the Peerless might be a btter choice?
Do you think either of these will work ok with my power? Thanks :)
Discussion Starter · #9 ·
What was the 830491's mounting depth again? IIRC it was a little over 4" correct?
I can't fit deeper than 3.75" And that's with 1 3/4" spacer and trimming the inside of the door panel.
welp guess that the end of those lol
they were VERY nice , just get the daytons then is you can fit them
and if not those I dig my exclusives--but you lose some linear throw in comparison for improved sound and midrange potential
cant have everything I guess :)
If the XLS is a problem to find, get the Dayton RS225... The Daytons look like they would match the Peerless ESC in mid potential & have more XMAX to boot.
1 - 20 of 20 Posts
