1 - 5 of 5 Posts
Anyway...
I have searched and could not find the physical dimensions of the Lotus silk tweet. I need to know the cutout diameter, total diameter including any flange area, and depth. Thanks for the help.
haibane said:
If you still need em in the morning I will get them for you, but basically they are some of the biggest suckers you have ever seen
They can't be any bigger than my Dayton RS I am trying to shoehorn into sail pillars! :mad:
Mounting cutout 45.99 mm
Mounting depth 30.55 mm
http://www.seaslotus.com/specifications.asp
the overall diameter is about the same as the seas tweet as there is technically no flange (may 2 mm or so)
they are mounted from the rear using this spring type metal strap that screws into the bottom, then sort of "butterfly's off to both sides
hard to explain if youve never seen it before
i used mine off 100W @ 4ohm remember they are 6 ohm though
1 - 5 of 5 Posts
