Efficiency was a bit lower than expected, but then again the bass extension was much better. The driver tested was well broken in, having been used in my car for over a year. This driver would work well free-air in the doors. The response is also pretty ruler flat, except for of course that nasty peak at 4.5khz.
No surprises here... nasty cone breakup at 4.5khz.
800hz decay. Perfect.
1200hz decay. Good, but getting worse.
1600hz decay.
2000hz decay. Significantly worse. Looks like ~1600hz is the upper limit. However for car audio use this doesn't really matter since your doors will contribute significantly more energy storage than the speaker.
2500hz decay.
3000hz decay.
4500hz decay. Ouch.
Distortion 50hz. Fair performance.
Distortion 60hz. Fair performance. I'd probably cut the driver off here for car use, although 50hz is certainly doable it is noticeably "dirtier" than 60hz.
Distortion 80hz. Good performance.
Distortion 200hz. Good performance, but I was expecting better.
Distortion 1000hz. Very good performance. Below 1%.
Distortion 2000hz. Again outstanding.
Distortion 3000hz. Not too good. I'd keep the driver below 2000hz, although again for car use this is acceptable.
Distortion at 4000hz.
Xmag = -7mm to +6mm
Xsus = -2.5mm to 7.5mm
Xmax = 2.5mm 1 way
Overall a good driver. A few things to note. Distortion performance and energy performance above 2khz gets bad, BUT still very useable for car audio. If this is going in a door, I'd say go ahead and use it full range without a lowpass or a notch filter. At all other frequencies between 80hz and 2khz, this driver is below 1% distortion and an excellent performer. The frequency response is also ruler flat minus that nasty breakup at 4.5khz.
Efficiency is a bit lower than expected at ~85db, but the bass response is much more ideal for free-air use in the doors. I wouldn't be surprised to see flat response to 20hz for most car doors (properly treated of course).
Xmax 2.5mm??! Well, yes. The suspension has a huge forward bias. The travel outward is much greater than rearward travel. This is to prevent the spider from smashing into the top plate. Keep in mind that the peak to peak travel is about 20mm... it just won't be "linear".
I was also surprised at the BL curve. Not quite as good as I'd imagined. Bl is fairly symmetrical and very good, but not as flat a plateau as others I've tested... in other words not the best. LE variance is outstanding however.
All in all, I'd say it's still a great driver. Low distortion, excellent bass response, and great linearity (except for the suspension).
1600hz decay.
2500hz decay.
3000hz decay.
4500hz decay. Ouch.
Xmag = -7mm to +6mm
Xmax = 2.5mm 1 way
