Currently running active with GS690 and GS10 with a Kicker Key 200.4 in bi-amp mode behind the stock radio. I was trying to keep everything lower cost and simple in the new vehicle. Nice improvement over stock but damn am I missing that midrange driver!
Kicker Key's auto detect crossover settings state:
• Woofers and Tweeters: 3.2kHz 24dB/oct High Pass for the tweeters, 3.2 kHz low pass for the woofers
• Woofers and Dash Speakers: 320 Hz 24dB/oct High Pass for the dash-speakers, 640 Hz low pass for the woofers.
I want to add a GS25, but I also wans to keep my tweeters and I'd love to not wire in a larger amp. I'm thinking getting a set of passive crossovers to run the GS25s and GS10s, stack them tight and vertical in my sail panels and put them on HF channels of the Key. The Key would see the frequency response from that channel as full range and cut them off as "dash speakers." I figured stacking the GS25 and GS10 vertically and projecting the GS10s a bit forward would mostly alleviate the time alignment difference.
Any reason this is a terrible idea? I was considering the GS410c crossovers.
