Here you go ...
ALPINE MRP-M650 MONO Car Subwoofer Amp *[email protected]@K!* 600W - eBay (item 220396333152 end time Apr-19-09 16:49:27 PDT)
mebbe this one it includes xtras...
http://cgi.ebay.com/Rockford-Fosgat...4|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Max power output 3000 WATTS+ (actual birth certificate power will be closer to 3400-3800 watts)
400 watts continuous minumim RMS power @4 ohms- actual power will be greater
750 watts continuous minimum RMS power @ 2 ohms- actual power will be greater
1100 watts continuous minimum RMS power @ 1 ohms- actual power will be greater
Monoblock Class AB design
MOSFET power supply
DTM-Dynamic Thermal Management
focused mass heatsink design
Remote PEQ level input- controllor sold separately
8-18 Ga speaker terminal inputs
4 Ga power and ground connections
Built-in selectable 28 hz infrasonic filter
Built-in selectable lowpass crossover- variable from 35-250hz @12db/oct
On-Board Punch Bass EQ Adjustable bass boost up to +18db @45hz
Custom designed TO-247 MOSFETS run cooler than standard transistors
Thermal sensing
Stauts display LED's for Power, thermal overload, and speaker protection circuit
CEA 2006 Compliant
RCA inputs
RCA Pass-Thru outputs
Frequency response 20-20,000 Hz
Dimensions=14.4"W x 2.2"H x 7.7"D
