I had one thing installed by a shop.....ever. It was a basic amp kit because I was working a lot back then when the car was new and did not have the time. Fast forward 5 years, I've replaced every piece of equipment in the car except for the power wire. I just placed a huge order from Knu Konceptz because I've basically been using Radio Shack RCAs and overall cheap wiring components. I have a fuse at the battery of course and each component has it's separate fuse close to the component.
What I just discovered while ripping everything out was that they used 4ga aluminum wire from the battery to the distro block. I have no idea how I never noticed this before. Everything else is 4ga copper to the amps and grounds that I installed.
I'm downsizing from a MacIntosh 430, JL 6 channel, and a 1,000w Infinity amp on the subs to either two HD 600/4s and a 750/1 or one 600/4 and one 900/5. I currently have the one 600/4 and purchasing the other HD amp(s) soon.
What's kind of scary is at one time I had 3 class A/B amps including the sub amp running off of that wire.
So should I upgrade the power wire that's feeding at least a pair of HD amps and an MS8? I have a feeling the answer is going to be yes but I was curious if doing so would be overkill. The HDs are efficient and my subs require very, very little power.
I just saw that Knu is having that half price sale on the power wire.
is it full up AL wire or is it CCA? nothing wrong with AL but you do have to compensate with a bigger gauge than you would use for CU.
