21 - 40 of 64 Posts
Do you recommend building an enclosure for the 6.5"s in the kick panel area or just running them infinite baffle type in the kick vented to the outside. Mid/highs will be ID horns (pro).. so these are mid bass duty specifically with alot of power going to em. Trying to stay away from installing/cutting the doors (69 El Camino).
Discussion Starter #23
I'd do some WinISD modeling before building your enclosures to see what to expect. Mine are mounted to the door in typical fashion, so should be essentially IB. I know they work well this way, delivering close to the advertised FR curve.
Since i had a pair of these lying around i modeled them assuming my doors were 2cuft enclosures (their actual volume).
The F3 bass roll-off frequency of the silver flues was an awfully high 153Hz. No wonder they sounded weak and lifeless in my application.
Contrast that to my HAT Imagines (95Hz) and the stunning Dayton RS 180 (58Hz)
Discussion Starter #25
It looks like the F3 of the flutes in my doors is right at about 60 hz. That's working well with my 65 hz crossover point.
I just finished up revising my TA to better sync with the sub, and now the bass in my car is excellent. Especially considering the two mids and sub together cost a total of $120.
Discussion Starter #27
I've got the outer skin fully covered, and most of the inner skin as well. I've also got a Deflex pad behind them glued over the sound deadener. Can't hurt. They're pretty cheap, and can't take on water like a foam could.
Has anyone tried a 3 way setup using these woofers? I've been thinking about picking up a pair of CDT EX30 crossover, 5" SilverFlute woofer for the midrange and the 6.5 or 8" in the door as the woofer, not decided on tweeter but maybe one of the Vifa ring tweeters.
5" and tweeter would be in a sealed up kickpanel similar to Qlogic but deaden with hardening puddy and mdf baffle/brace and the woofer would be in a deaden somewhat sealed up door.
Really with all the drivers and the Xover it would be well under $400.
Discussion Starter #29
I'm going to get some of the 5" Silver Flutes as well to put in my 68 AMX. I've got a few crossovers lying around - pretty much anything is workable with the Flutes since they can run so high. Just need to find a nice set of tweeters with angle mounts.
Did you include the effect of the car's transfer function in your modelling?
Discussion Starter #32
The doors on my Mazda3 measure out to approximately 2.0 cu ft as well, and the F3 I get from actual near field measurement is 60 Hz.
I don't think you can model a typical car door as a sealed box and get accurate results. Most people seem to look at them as IB installations, but I don't know how to get Winisd to do IB. When I make the box really large it doesn't seem to influence the result much.
It's possible that the published specs on the drivers are incorrect as well.
understood. however since i am tired of trying drivers based on word of mouth and other review related info i decided to try and model the response as if the doors were sealed enclosures. they are fairly tight if you do a good job of sealing them and have the window up.
for a lot of drivers, especially DIY, you can see a correlation. i have run (3) different 6.5" drivers in my doors, the silver flutes, focal 165V30 and the HAT imagines l6. when modeled they have approximate F3s of 142Hz, 72 Hz and 97 Hz respectively.
all seem to bear this out when you hear them installed.
i liked the focals and they did play lower but they also had a bad resonance peak.
if you model larger e.g. 8" drivers you start seeing lower F3 numbers. it is what you would expect.
i modeled many 6.5 drivers and the one with the lowest F3 is the Dayton rs180- F3 of 53 Hz. many people love the bass these have. unfortunately they are too deep for my doors.
i am seriously considering the dynaudio esotec 172. they are a smaller 8" driver and they show an F3 of 63 Hz.
it may not be a direct apples to apples comparison nor does this number predict every sound characteristic of the driver but it is a basis for comparison as opposed to just trying drivers with only the information of other's experiences which include so many variables.
I know there's a couple of vendors/websites out there, but which do you guys recommend buying these from?
I want to try them out (both in car and shelfs) but wanted opinions in who has the best price and overall customer service. Thanks.
Discussion Starter #36
Me too. They were $70 shipped and came in 4 days, packaged perfectly with form fitting styrofoam.
Discussion Starter #37 (Edited)
It's probably worth mentioning here that I looked at both the RS 180 and the Silver Flutes initially. My Hertz tweets were originally crossed at 3500 hz, and the RS 180 is only rated to 2200 Hz, plus I've seen independant tests that indicate its FR gets nutty above 1200 Hz.
The RS 180 is only rated for 60 watts rms while the Flute is rated for 80 watts, and there is also the price difference - the RS 180 costs 70% more then the Flute.
So in a 3-way the RS 180 is a no brainer if you have the depth, but in a 2-way it would be tougher to match up with some tweeters.
As my flutes break in they are sounding much nicer. I'm very pleased with them so far. Still have some tweaking and door work to do but so far, I would recommend people give these a shot for sure. Worst case scenario, you don't like them, resell them on here and don't end up losing a bunch in resale value.
Madisound is awesome. I bought a pair of silver flute 6.5" 4ohm units and blew one up in the first day - probably my fault though the other side did just fine with the same setup. Anyway, I contacted madisound and they sent a new woofer out to me inside of a few days, free of charge. They have my business for life.
PS, I love them. I actually ditched a pair of dyn mw163gts for them. I should say the dyns will hold more power without distorting but only just, and I was trying to beat the life out of my midbasses and didn't want to be on the hook for $300-400 if I blew a woofer. The flutes have held the 150+ watts rms I've been giving them for a year now, highpassed at 80 Hz 12db/oct in the sealed and deadened doors of my 98 Jetta.
Good to read that, i just placed my order for a pair. Can't wait to try them, worse casescenario I'll remove them from my vehicle and build a small sealed enclosure for them.
21 - 40 of 64 Posts
