Hello everyone! Im working on a box for my Aurasound NS10, going off of thier recommended 1.6cu.ft. ported design. I'm using the calculator software at, "http://www.carstereo.com/help/Articles.cfm?id=31" and am running into a little bit of trouble. Before, i didn't quite understand the whole port-noise idea so I used the lower calculator only and made a 2.25"x4" port on the box. Well i finished it and now i DO understand port noise!
The results of the port noise calculations are thus:
Minimum Diameter = 5.81 inches
Minimum Area = 26.51 inches
Length of a side for a square vent = 5.15 inches
Since I have more of the 2.25" tubing, i was thinking the easiest way would be to take the tube that's in there out, and add two more round ports. When i enter "three round ports x 2.25" each" into the port length calculator, do i enter the "Desired Port Diameter" as 5.81" or 2.25"?
Is the resulting number for EACH of the three ports, or do i take that number and divide it by 3 and do that length for each port?
This is all assuming that the 3x 2.25" ports will indeed NOT have port noise since they equal larger than 5.81" total...right?
