Just out curiousity.. Why would you suggest he uses one as a PR to begin with?
My first question was about isobaric.
Maybe we talk about that before a PR?
Gotcha.. thanks for the reply.My first question was about isobaric.
They work by using the "air spring" the active woofer creates so they are useless in their own air space.But typically wouldn't you want the PR sharing the same box space? I've never used a PR before so that is a sincere question..
That would be correct, and I read Holmz post the same way you did ...But typically wouldn't you want the PR sharing the same box space?
Sounds like he suggested that a single sub with a PR is what should be done /shrugOr one ends u with a PR, which is where they should have started anyhow.![]()
That's I was I thinking. I know PR are popular in home audio towers that may have 4 x 6" cones with 2 of the 4 acting as PRs in addition to the mids, tweets, etc.. but at what point is it better to use a PR in a car audio application?They work by using the "air spring" the active woofer creates so they are useless in their own air space.
Sorry, my bad. I have Holmz blocked so i don't see his responses. I saw this one from SLOVIC that i thought you were referring too.Did not @Holmz suggest that if one ends up toast, he would end up with a PR which is where he should've started?
Or maybe I just misunderstood his post.
Usually we throw out ideas.That would be correct, and I read Holmz post the same way you did ...
For what it's worth, I don't think it is necessary to worry about and plan around blowing up your gear ... unless you are that person that is constantly blowing up their gear.
Wow, i am popularSorry, my bad. I have Holmz blocked so i don't see his responses.
Also, Holmes has a thing about PR's and thinks everyone should be using them. Problem is they just are not that practical in cars.
That is not exactly accurate....
Its always been a way of being able to get the desired response of a ported box without having to have the internal volume. But the problem with that is not you can have ported boxes with much less airspace than in the past. So when dealing with say 1.5 cuft, its hard to fit a woofer, and the required 2 passive radiators in a way that makes sense with the existing baffle space. I figure in another 10 years the desired subwoofer configuration will be servo driven subs.That's exactly what I was thinking.. but like I said, I never used them just because it seems like a waste of woofer.. and if moving air is the goal you'd think you'd wanted that 2nd woofer powered instead of just re-flexing off the other.
That second sub would be lighter, and cause the it to unload be tuned higher.That's exactly what I was thinking.. but like I said, I never used them just because it seems like a waste of woofer.. and if moving air is the goal you'd think you'd wanted that 2nd woofer powered instead of just re-flexing off the other.
Its always been a way of being able to get the desired response of a ported box without having to have the internal volume. But the problem with that is not you can have ported boxes with much less airspace than in the past. So when dealing with say 1.5 cuft, its hard to fit a woofer, and the required 2 passive radiators in a way that makes sense with the existing baffle space. I figure in another 10 years the desired subwoofer configuration will be servo driven subs.![]()
Assume one of the woofers does in deed die. Unhook it from the amp of course but leave it in the box.. and so long as the coil is not just seized to death it becomes a PR. Is this correct? And if so, how does the sub that is still alive die? I've never heard of woofers straight up dying because they were in a box is 2x MFGR Recommendation. And were not talking refoaming or something, we are talking coil/motor failure due to being an too big of a box?That second sub would be lighter, and cause the it to unload be tuned higher.
So one either needs a PR in the hole there, or a plug and us an aero port.
or another powered woofer in the hole.
It would sound snappy for a while and the remaining subs suspension would fail.
If one sub failed then that would act as a PR, but we tuned very high and be a vented box that is 2x larger than a sealed box...Assume one of the woofers does in deed die. Unhook it from the amp of course but leave it in the box.. and so long as the coil is not just seized to death it becomes a PR. Is this correct?
That "2 sealed in a box" is probably in the ball park of being the right volume for a single ported box(?), however the light sub would be too light for a low tuned PR, and the good sub would fail from a suspension failure or ripped up cone, or some bottoming out failure.... And if so, how does the sub that is still alive die? I've never heard of woofers straight up dying because they were in a box is 2x MFGR Recommendation. And were not talking refoaming or something, we are talking coil/motor failure due to being an too big of a box?
Or am I simply misreading/misunderstanding your reply?
I got you man.. Now I understandIf one sub failed then that would act as a PR, but we tuned very high and be a vented box that is 2x larger than a sealed box...
So yeah...
But it would be tuned all wrong.
The main point was that a "shared volume dual sealed' allows for a dual sealed, and maybe a PR? or even a plug and a port in the second hole.
Really mniSQ generally knows this sub stuff.I got you man.. Now I understand
(so ignore my ravings.)
Personally, I would go with the single 10. Reasons being that it can hit a little lower then the 8s a d given you'r amount of power, twin 8s might be a little underpowered with 300 watts. I would think the single 10 would operate better with that amount of air space then the twin 8s.Given the option of a single 10" D4 or a pair of 8" D2 subs with the same 300W mono either way, why would you go one way or the other? The pair of 8s has about 30% more cone area and 2mm less Xmax but 4 coils running off that 300W. Image Dynamics ID are the specific subs in question. Would your answer change if we were talking about Alpine Type R?
EDIT - only considering sealed enclosure due to space.
If I remember my theory correctly it will halve the box size but you will lose 3dB.Would isobaric do anything useful?
