Hello to you all 😀
I am looking for some advice on an active crossover or eq to be boot mounted.
In short what I am looking for is to turn a single rca that I have run to the rear to be some at least 3 outputs - front rear and sub.
Because I’m using a 4 Chanel amp for the subs two sub outputs would be ideal .
As mentioned it is essential that it will work from a single rca input price wise around 200-300£ and uk is the location 😀
Thank you 😀
Thank you 😀
