nm oops
CorrectTheoretically it is fine. It won't do any damage. You just lose output.
It raises the Q. I read somewhere about this being done for HT IB setups.
The bolded portion you lost me on. What does only wiring a mono amp have to do with ony running a single voice coil?seen what it is is i have a rockford p3d210 which is a dvc 10" dual 2 ohm and i wanna take advantage of a mono amp as my next system. i have decided the new amps i will get is either 2 pioneer premnier prsd2100t's or a rockford p300-2 for my 3 piece fronts and a p500-2 for my sub channel but i would love to get a mono amp. if i could then i could wire a single coil.
I can go on and on with your ****. I can even show where you used to say RF is complete CRAP, junk ect. OOOPS and now you are talking about running.they were very good and because i used so much dynamat, the mid bass was clean and rich. i had the same jl 3 ways in the 1987 corolla which i received 3 1st place trophies in sound quality for and one score sheet was at 98 % a flat response. also no active processors! Though i like the alpine piece.
