Well, I tried asking this over on ECA with no luck, so I figured this would be a more appropriate place to ask anyways :twisted:
I have some 8" RS225's and the RS tweeters sitting here on the floor that I'd like to install as a 2 way setup in my car. My question is, how large/small of an enclosure should I glass for the woofer?
Specs are as follows:
*Power handling: 80 watts RMS/120 watts max *VCdia: 1.5" *Le: 1.0 mH *Znom: 8 ohms *Re: 6.4 ohms *Frequency range: 27-2,000 Hz *Fs: 27 Hz *SPL: 88.1 dB 2.83V/1m *Vas: 2.75 cu. ft. *Qms: 1.60 *Qes: .47 *Qts: .37 *Xmax: 7 mm *Dimensions: A: 8-3/4", B: 7-3/8", C: 4".
According to this:
http://www.bcae1.com/spboxad2.htm
I came up with just under a ft^3 for each driver. I have no idea what else to go by. Note the Vas spec.
If anyone can help me out I'd mucho appreciate it
-aaron
According to this:
-aaron
