Seems like most off the shelf ported boxes are tuned high to get "louder"
I'm not thinking its entirely the box causing the problem. But you can also extend the port outside the box to test a lower tuning freq.i'll get pics of amp settings asap. at work right now. Checked skar website again and now it says that 12 inch single prefab is tuned to 36hz. Sub suggests 32-36hz. I'm also questioning their port dimensions. Without ripping it down probably will never know.
You can determine tuning frequency by playing tones and observing cone movement. Here's an example with a PR tower, but the principle is the same (i.e., active cone will have least excursion at tuning frequency):i'll get pics of amp settings asap. at work right now. Checked skar website again and now it says that 12 inch single prefab is tuned to 36hz. Sub suggests 32-36hz. I'm also questioning their port dimensions. Without ripping it down probably will never know.
the sub amp crossover is undefeatable. I didn't want to use headunit and amp crossover both at once. I am using the HU xover for front and rear though.You said your Head unit has crossovers? Why not use exact crossovers instead of the ones on the amp?
I agree that 27hz is too low for subsonic but i was basing off the box being tuned at 32hz. I'm going to try and see where the dang box is actually tuned then readjust subsonic.The subsonic can be set to off and the LPF at its highest setting (220hz) and it won't affect the HU crossovers. But if you think you got it covered with the amp, that's cool too. But 27hz subsonic is low for a box that's ported at 40hz.
This was really neat! I tried with my sub except had to use popcorn kernels. My box is right around 33-34 Hz.You can determine tuning frequency by playing tones and observing cone movement. Here's an example with a PR tower, but the principle is the same (i.e., active cone will have least excursion at tuning frequency):
Online tone generator:
Online Tone Generator - generate pure tones of any frequency
www.szynalski.com
