1 - 11 of 11 Posts
I bought about a month ago but ended up also with a Pro MKII that I will use.
This has never been out of the plastic.
$550 and I'll cover shipping to 48 states.
258699
258700
Let me just say that the DSP.3 is fantastic DSP. For this price, don't hesitate if you are looking to upgrade to a top-of-the-line DSP!!! I recently upgraded from a Rockford Fosgate DSR-1 to an AmpPro4 / DSP..3 combo and have been VERY happy with the results!
I think this may only have 8 rca outputs instead of the 10 listed above. As my name suggests, “I am new” to an extent, and could be wrong.
You are correct - my error, obviously copied the wrong data. Thanks for pointing this out. Will correct!!!
Inputs
6 x RCA / Cinch
6 x Highlevel speaker input
1 x Optical SPDIF (12 - 96 kHz)
1 x Remote In
Input sensitivity
RCA / Cinch 2 - 4 Volts
Highlevel 5 - 11 Volts
Outputs
8 x RCA / Cinch
1 x Remote Out
Output voltage
6 Volts
Frequency response
10 Hz - 44,000 Hz
DSP resolution
64 Bit
DSP power
295 MHz (1.2 billion MAC operations/second)
Sampling rate
96 kHz
DSP type
Audio signal processor
Signal converters
A/D: Asahi Kasei 32 Bit
D/A: Asahi Kasei 32 Bit
Signal-to-noise ratio digital input
114 dB (A-weighted)
Signal-to-noise ratio analog input
110 dB (A-weighted)
Total harmonic distortion (THD+N) digital input
< 0.0006 %
Total harmonic distortion (THD+N) analog input
< 0.0015 %
IM distortion (IMD) digital input
< 0.003 %
IM distortion (IMD) analog input
< 0.005 %
Crosstalk
> 90 dB
Operating voltage
9.6 - 18 Volts (max. 5 sec. down to 6 Volts)
Current draw
< 450 mA
Max. remote output current
500 mA
Additional features
HEC slot, Ground lift switch, Control Input, 32 Bit CoProcessor, ADEP.3 circuit, Auto Remote switch
Dimensions (H x W x D)
40 x 177 x 120 mm /
1.58 x 6.97 x 4.72”
1 - 11 of 11 Posts
