Never used or installed. Opened. Missing bass knob cable(3.5mm) includes bass knob(unused)
+free brand new TX35 - 3.5” coaxial/tweeter combo 60w 4ohm
$165.00 shipped
With a depth of adjustable user controls such as the gain, LPF, HPF, Crossover Controls, and Bass EQ, this amplifier is extremely versatile and can be used in numerous applications.
Skar Audio RP-600.5 Multichannel Amplifier
Class AB/D 5-Channel Amplifier
4 Way Protection Circuitry: Thermal, Voltage, Speaker, DC
RMS Power at 4 Ohms: 60 Watts x 4 Channels + 250 Watts x 1 Channel (14.4v)
RMS Power at 2 Ohms: 90 Watts x 4 Channels + 300 Watts x 1 Channel (14.4v)
RMS Power at 1 Ohm: 400 Watts x 1 Channel - 5th Channel (14.4v)
RMS Power at 4 Ohms (Bridged): 180 Watts x 2 Channels (14.4v)
High Speed MOSFET Power Supply
Soft Turn on Circuit
Frequency Response: 20Hz - 20kHz
Signal to Noise Ratio: 105dB (CH1-4) / 85dB (CH5)
Bass EQ Switch: 0dB - 12dB
Low Pass Filter (Variable): 50Hz - 500Hz
High Pass Filter (Variable): 20Hz - 5kHz
Subsonic Filter (Variable): 10Hz - 50Hz (CH5)
4 Gauge Power and Ground Terminals
Working Voltage: 8.5V - 14.4V
Fuse Rating: 80 Amp
Dimensions: 16.93" (Length) x 6.30" (Width) x 2.20" (Height)
Ordered it and ended up wanting a rear deck now that I’m finally installing so just not enough channels for me.
$165.00 shipped
Fuse Rating: 80 Amp
