1 - 2 of 2 Posts
Brax MX4 - Used
See the specs below.
See the pictures attached.
Price - $1650, includes shipping fees.
Output power RMS
  • @ 4 Ohms 4 x 275 Watts
  • @ 2 Ohms 4 x 280 Watts
  • @ 1 Ohm 4 x 285 Watts
  • bridged @ 4 Ohms 2 x 550 Watts
  • bridged @ 2 Ohms 2 x 560 Watts
Amplifier technology Class AB
Inputs 4 x Cinch
2 x Optical SPDIF (12 - 96 kHz)
1 x Remote In
Input sensitivity RCA / Cinch 1.0 - 8.0 Volts
Input impedance RCA / Cinch 10 kOhms
Input impedance highlevel -
Outputs 4 x Speaker output
Output voltage RCA / Cinch -
Signal converter for digital input BurrBrown 24 Bit DA converter
Frequency response 10 Hz - 80 kHz
Signal-to-noise ratio digital input > 110 dB (A-weighted)
Signal-to-noise ratio analog input > 110 dB (A-weighted)
Distortion (THD) < 0.001 %
Damping factor > 1000
Operating voltage 9 - 16 Volts
Idle current 8.5 A
Fuse 6 x 25 A LP-Mini-fuse (APS)
Additional features Colour Protection System, BRAX Power Stabilizer connector, Start-Stop capability
Dimensions (H x W x D) 79 x 360 x 360 mm /
3.11 x 14.17 x 14.17"
Net weight 11.5 kg
1 - 2 of 2 Posts
