1 - 9 of 9 Posts
ITEM BRAND & MODEL #: Hybrid Audio L8SE Midbass Drivers
CONDITION:
(Used / 8.5-10)
As you can see, there is a small blemish/imperfection on the magnet of the second driver - see the photos below.
PRICE: $375.00
SHIPPING:
Included
PAYPAL FEES: Included
ADDITIONAL INFORMATION:
ModelLegatia L8SE
Size8.85-inch
AvailabilityReady to Ship
Overall Diameter225 mm
Mounting Depth94 mm
Bolt Circle Diameter84.5 mm
Mounting Hole186 mm
Pnom (Watts)60
Pmax (Watts)120
Freq. Response40 Hz - 2 kHz
Sensitivity at 2.83 V/1 meter.92 dB
Mms2.561 g
Cms369 μM/N
BL (Series / Parallel)3.017 T*m
Voice Coil Diameter50 mm
Impedance4
Fs41 Hz
Qms2.182
Qes1.467
Qts0.877
Xmax (two-way)4 mm
Vas0.508 L
Sd13,685 mm2
Suggested Power w/ crossover225 Watts
Suggested crossover @ 24 dB185 Hz
Recommended Airspace (per driver)43 L Sealed
50 L @ 28 Hz
PICTURES: See Below
Killer price on these Huck! Love mine. Won’t last long at that price. GLWS
Reactions: Huckleberry Sound
As I said...won’t last long. Congrats!
Are you running a 2 or 3 way? The frequency range posted by seller differs from 12volts website. 2k and 4K respectively.
This is from the HAT spreadsheet...
301024
Im running 3 way. Built kicks for them so not sure where I’m gonna cross them just yet until I get everything installed. Never had them in kicks before. Still have to put a final coat of ez sand and vinyl wrap them and then I can supply better info.
301025
Looks fun! Plan is to shoehorn this into my doors. Thank you for the spread sheet. The way I read that is the l8se with phase plug plays to 3.8k while the model with the dust cap only plays to 2k..how can that be? I sure hope it’s 3.8k as I’m going 2 way. I guess I can always break out the fiberglass like you and make some pillars and get some mids if needed lol.
1 - 9 of 9 Posts
