So I am considering starting a project but have a few concerns and questions before I start
The Plan:
Create a self contained stereo unit in a a single enclosure from an old car stereo system to use as a home stereo and as an amplified speaker for mixing with (turntables) I want to be able to plug in to ac and work
The Components I already have:
2 x 12" Rockford Fosgate Punch p3 2004 series 500w rms subs
2 x 5-1/4" Infinity reference 45w rms 2-way speakers
2 x 4"x6" Alpine type S 45w rms 2-way speakers
1 x P500-2 Rockford Fosgate 500w 2channel amp
Pioneer 25w per channel head unit (don't have model at the moment)
Questions:
What is a proper bass to mids power ratio? 1000w vs under200 seems a huge difference. When I bought the system in 05 I just wanted it to thump.
Do I need one or two 2channel amps to run the four speakers at the correct wattage?
The calculator says my subs are right on the line between sealed and either on the sealed side, but I always wanted them ported is this a bad idea?
Should each sub be in its own separate space with an internal divider as I had in my sealed box in my car or would a shared space be better? Also the speakers should have separate or shared spaces?
How many amps would a dc converter I get need to support?
If I did a ported box with separate section for each sub would it be wise to tune them to different frequencies or the same?
I know this is a lot of questions, any and all answers and suggestions are greatly appreciated.
The Plan:
Questions:
