1 - 20 of 34 Posts
Hi guys,
I have a complete Sony XES-Z50 for sale. It's in near perfect condition as you can see on the pictures.
What you get in the whole package:
- 10x CD changer with included XES DSP
- head unit with a system remote control and a rotary commander
- additional replacement parts: display and 2nd rotary commander
- system connection cable (not displayed on the pictures)
- XES advertising / brochure
- original user manual in German (in a leather wrapper!)
- Z50 service manual on paper and as PDF
- aluminum dealer plate (exclusively provided to authorized XES dealers)
- cables and mounting kit for mounting the display separated from the tuner unit (not displayed on the pictures)
AND: VERY RARE:
- programming interface for setting up the DSP (x-over, time alignment) via RS232-interface and a laptop. ONLY WITH THIS pogramming interface it's possible to put the headunit into the "hone mode" that allows to reduce the original x-over frequency to frequencies lower than originally allowed.
I'm from Germany - so the complete package has to be sent overseas. I will check the costs for shipping to the US.
I'm demanding 3000 € for the complete set - that are ~4183 $US (exchange rate from today).
There is some other XES stuff available, too:
- 4 Sony XES-M50 amplifiers (3 are painted, 1 is original, but slightly scratched)
- 2 Sony XES-L50 subwoofers
- 2 Sony XES-F50 16cm (6 inch) wideband speakers
- 2 Sony XES-H50 tweeters (ribbon tweeters)
Cheers
Konni
Could you tell me what the crossover and eq specs are?
I will check the exact x-over frequencies today. The equalizer is parametric and has 10 bands per side.
I will post exact information about x-over, time alignment and EQ later this day (10:25 o'clock am in Germany right now).
Cheers
Konni
Hi, would you sell the programming interface separately?
Only if the buyer of the whole system doesn't need this.
Some pictures from the M50 amplifiers:
The price per unit: 400 € --> ~560 $US
And if you're interested in a set with the speakers:
- Z50 (headunit, changer with included dsp, etc. everything described in the 1st post)
- 3x M50 amplifiers
- all the speakers (2x L50, 2x F50, 2x H50)
5000 € for this set (~7000 $US) - basis for negotiation! You can make offers for the whole XES system.
Cheers
Konni
Discussion Starter #12
Now the facts:
- 6 channel dsp with front/rear/sub respectively high/mid/low
- each channel level can be adjusted in 0.5 dB steps down to -12 dB
- 12 band parametric EQ, frequencies can be chosen arbitrary per channel, -12.0 dB to +12.0 dB in 0.1 dB steps, bandwidth Q adjustable from 0.1 to 25.5 in 0.1 steps
X-Over:
Sub LP 78/88/99 Hz with 72/36dB slope
Mid HP 78/88/99 Hz with 72/36dB slope
Mid LP 500/629/793/1000/1250/3170/4000/5030/6340/8000 Hz with 72/24/12/0 dB slope
High HP 500/629/793/1000/1250/3170/4000/5030/6340/8000 Hz with 72/24/12 dB slope
The bold marked frequencies can only be set up in hone mode with programming interface!
Time alignment has a resolution of 0,25 inch steps (1 cm) up to 984,25 inches (25 meters) per channel.
Cheers
Konni
Dam:surprised:
Will Like to get back some the whole system..:)
But will like get the programming interface:D
XES-Z50 still is BEST of BEST:rolleyes:
Discussion Starter #20
Anyone that makes Tristan react like that deserves a bump.
:thumbsup:
I just got the 2nd request for the programming interface. But I won't sell this item separatley. Only if the buyer of the system doesn't need this.
Cheers
Konni
1 - 20 of 34 Posts
