Sound Deadener Showdown has closed its doors
60408 Views 174 Replies 52 Participants Last post by  angola
I’ve been trying to get ahold for of Don from SDS to no avail and noticed today that his website was “down for maintenance”.
Well Don finally emailed me back:
“Chris,
I've retired and SDS will not be selling any more materials. Sorry. I'll refund your payment.”
Looks like the provider of the best CLD tiles out there has gone out of business.
Reactions: 3
141 - 160 of 175 Posts
I'm interested in how much of a measurable difference there is by doing 100% CLD coverage vs 30% CLD coverage with CCF/MLV on top.
Just to be clear, I am not trying to confuse the issue between using CLD as a resonance inhibitor and MLV as a sound blocker, but am wondering if using a more dense CLD at 100% coverage will also help to block more sound transmission as well. My gut feeling is that it will!!!
I am wondering if there is a large difference with covering a panel fully in CLD with the usual materials on top vs only 30% CLD with the same dampening on top.
The difference in mass and weight is that you factor in a gravitational constant for weight. Mass is the same no matter where you go. Weight will depend on gravity. Density = mass over volume.
OK, thanks for clarifying the terminology, but I do not think that it changes the basic relationship between a material's density and its ability to block sound transmision nor the fact that KKK is almost as dense as MLV, at least when used at the same altitude at the same time, right??
Nope would not matter. I kind of doubt you'd even be able to tell any difference among elevations anywhere on earth assuming a uniform temperature.
Not just as effective, but its where diminishing returns starts
Sent from my SM-G950U1 using Tapatalk
Yeah I subscribe to this as well. Sometimes you have to layer up, like when an 18" subwoofer is downfiring into the spare tire well. LOL.
For me, my target is 25-30% of the straight metal. Curved and otherwise creased sections get less attention.
For a topper of CLD, I use all sorts of things but I have an affinity toward the 1/4" and 1/8" Neoprene mentioned earlier from Foam Factory. I get the B-stock stuff since it is invisible once installed.
Kolossus has the advantage overall damping but at nearly 2x the weight. Its not clear to me if the damping improvement would be worth the weight sacrifice.
Kolossus: .93lb/sqft (33.48lb total)
DM Extreme: .45lb/sqft (16.2lb total)
Simple answer: How important is the weight of the car vs the sound isolation/deadening/whatever TO YOU.
I don't want to sound like an an ******* but at MORE THAN double the weight (not nearly) is there any real surprise that it wins out in terms of overall damping? IMHO I would say hell no and get Dynamat (et al). That's just me though :)
Peace
I love passive aggressive patronising one liner's.
Peace
The first part of your answer seems correct to me but also incomplete.
You are correct in that each person must decide for themselves how much money and time they want to spend deadening their vehicle in order to enhance it as a mobile SQ "listening room". Weight of materials used to both damp and quiet a vehicle is important to some people as it ALSO directly effects mpg, suspension ride, door hinge longevity in addition to the quietness and betterment of the vehicle as a listening space.
In terms of there being no surprise as to the weight and/or density of KKK as being more effective then other CLD, I believe you may be wrong as I am ALSO suggesting that it will contribute to the effects , or even partly replace the need for, 1#/SF MLV as long as it is used at 100% coverage
That being said, further experiments need to be done to actually determine if 100% coverage of KKK CLD is not only effective in reducing panel resonance, as we already know that it is, but also effective in also quieting the vehicle as MLV does, thus either reducing the need for using a thicker MLV, or PERHAPS even eliminating the need for it altogether given that it has near the same density as MLV and the importance of density in BLOCKING sound.
Reactions: 2
OK...yeah got you. Just as a side note what I said was a statement designed to elicit some discussion...the mention of it being incomplete was based on assuming what you have put forward is correct.
Prove me wrong!
A really interesting topic and I look forward to any further discussion mate :)
Definitely agreed in terms of the weight factor. To me (personally) that just rules it out straight away. To guys with bigger 4WD's and stuff that is likely not such a concern :D
Peace
Hmm...a reasonably well disguised riposte aimed to undermine the stated sentence and thereby entice more direct aggression. Didn't work and comment stands.
Peace.
So what's everyone's take on a high-temp resistant CLD tile substitute for SDS? I have a black car and it gets 120+ degrees where I live. The panels can literally get 170F+.
Dynamat Extreme and Second Skin don't seem so hot here. They both come off extremely easily:
https://www.youtube.com/watch?v=XWBzhEUG-LI
I've had zero issues with Raammat BXT over the years in Sacramento where it gets over 100 every year, and I park my car outside in the sun.
I dont understand why some people still go with 100% coverage when it's been proven 25% is just as effective
Does anyone know of any testing done to show the difference in NVH when using 25% CLD vs. 100%.
Not necessarily for NVH, but Chris (TooStubborn2Fail) did test varying coverage of CLD to see how it affected panel resonance. He also determined that single contiguous pieces are more effective than multiple pieces providing equal coverage. Here is his original post comparing partial vs "full" coverage.
https://www.diymobileaudio.com/forum/1945907-post277.html
Reactions: 2
I had always wondered about using one large piece vs covering the same amount of area with separate pieces. I didn’t realize he had also tested this.
I’ll re-read through the link you provided.
Thanks!
Am I reading that graph correctly when I say it looks like the part that's most affected is the energy between 70-100 Hz?
That means that for the doors with most mid-bass drivers having little energy below 100 Hz, it's not that big of a difference?
Peace.
Jesus dude, get a grip. You read into something that just wasn't there. Your comment can stand all it wants. IDGAF.
Seafish, if what I wrote came across in that way, that was not the intention.
The peak resonance in the panel was at ~85Hz. Adding 28.5% CLD widened the "Q" of the resonance and changed the peak frequency to ~73Hz and reduced it by ~14dB. 95% coverage pretty much entirely removed that peak resonance as well as reduced overall resonance below that peak beteen 5-6dB.
And I am not sure where you cross your midbasses, but I can't count the number of times I have seen people trying to push the crossover lower and lower on their door mounted mids. Including people (and some manufacturers) running "full range" or with very low (<30Hz) high pass filters. If I had to guess, most people have their door mounted midbasses crossed between 60-80Hz. Want to guess what frequency range is creating the most energy in the door in that case? ;)
Nope your comment only clarified the equation b/w weight, mass and density (I was smart enough to ignore the part about gravity), which I appreciate, even though it did not change the nature of what I was saying!!! IMO, it still ADDED to the actual conversation at hand, unlike some other poster's comments, some of which actually seem to be confrontational without even adding much at all...LOL!!!
Hmmmm.....I think you have a valid point. 80Hz is a very common crossover point. 14 dB is significant, but you get the whole enchilada with full coverage.
I hope we all have robust door hinges!
Don’t mean to sidetrack the CLD dialogue
But has anyone figured out the Velcro Don was selling. I tried the 3m Dual Lock product (both 250/400 and 400/400 versions) but it doesn’t come close to the strength of the Velcro from SDS.
I dont think anyone has been able to find it.
Sent from my SM-G950U using Tapatalk
