Subscribed
Is the goal of this test to show dampening performance after temperature exposure or to see the effects of extended heat exposure on the materials?There will also be durability testing for heat, using a small toaster oven. I'll use an oven thermometer to get the temps accurate.
That was my worry with it too, is consistency. Without being able to have a chamber to put everything in, including the accelerometer, it would be too hard to keep temps consistent. There is definitely a huge difference in smells though, even at room temps.I'm glad to hear that you are doing the temp tests for durability. Your nose might be a guide when it comes to determining failure point.
I think that if you were going to do a vibration at temp test series, you would be making a consistent test process a challenge.
predope sale; 50 % off pretty much everything. I only grabbed one 20 sqft pack but that should at least do the front doors which will be needed with my Morel 8s pounding them eventually with 340 Mosconi watts on them I think that pack worked out to about $80 or so and shipping was very reasonable - they sure have changed that for us Canadians - thanks alot Ant even if I chose to get it sent to Montana this time anyways. I also grabbed 100 ft of 16 ga and some 16 ga quick disconnects as well for the hell of it. It will be nice to have three runs of different looking wires on each side for the 3 way front. I probably have enough good wire already but this will be the third car these have been in and there are several areas on each line that have been soldered which I am sure affects the sq in some way. If nothing it will be easy to figure out which line is for what speakerAlphadamp was on sale over the weekend?! Ugh...
