1 - 1 of 1 Posts
sound qubed (audio qubed) 3500.1D
very very good
includes shipping
The Q1-3500D.1 is one of our most powerful Amplifier with up to 7500 watts @ 1ohm @ 18volts for those guys and ladies who want to push their systems to the limit. You can strap a pair of Q1-3500D.1'S for a woofer busting 15000 watts @ 2ohm. Born in the same place as our popular Q1-1200D and Q1-2200D and built with the very best parts money can buy the Q1-3500D.1 offers the best watt per dollar value in its power range.
WARNING
You MUST have an upgraded electrical system sufficient to provide the amperage required to handle the 380 amp fuse rating of the Q1-3500D.1 (760 amps for a pair) in order to satisfy this beast.
DESIGN FEATURES
The Q1-3500.1 is fully stable down to one ohm.
Daisy Chain connection of two Q1-3500.1 stable down to two ohms
Four way protection circuits: Speaker shorts, DC offset, High/Low voltage, Thermal protection
High current MOSFET switching devices
24db/oct slope crossovers, Fully adjustable Low Pass Filter and Subsonic Filter
Remote Gain Knob Included
Specifications
Model Q1-3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Clipping Display Led On Remote Gain Control
Signal to Noise Ratio 85dB <
Damping Factor 250 <
Efficiency 85% at 4 ohm <
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @ < 1% THD 4300W x 1
1 ohm Power @ 16V** @ 1% THD 5300W x 1
1 ohm Power @ 18V** @ 1% THD 6000W x 1
1 ohm Power @ 18V** @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Gauge x 2
1 - 1 of 1 Posts
