1 - 20 of 29 Posts
· Registered
Hello folks, this is my first post. I have a 1989 Ford E 350 diesel van / Born Free "President" RV converted to 4WD. The motor is the old 7.3 liter IDI International that preceded the Powerstrokes. To say the vehicle is loud is an understatement, and I have taken on the project of making it a lot quieter inside.
To start with, I have divided the project into three parts, the cab floor, the dog house, and the doors.
I pulled the thick household carpeting off the flooring. The metal underneath was in good shape. A fair amount of some asphalt looking sound deadener remained stuck to the metal, and I left it. I painted several coats of white latex primer atop it all, and then applied RAAMAudio vibration dampener to about 25% of the area. Then I applied RAAMAudio self adhesive 1/8" closed cel foam. Atop that I glued on mass loaded vinyl from Trademark Soundproofing via Amazon. I put on the MLV in many pieces, overlapping them or edging them together them up tight, and then Gorilla taped all the seams.
· Registered
Yes I know. Keeping an eye on this. Just so you know
You must feed our appetite for pictures. BTW welcome to DIYMA
· Registered
Got a picher of margharitas coming right up, as well as photographs. I tried to upload from my Samsung phone via my Chromebook, but the operation just stalled. I will try again from a windows machine.
· Premium Member
Photobucket is your friend...
· Registered
Yes use photobucket and use the URL to upload them
· Registered
Discussion Starter · #9 ·
So, from Photobucket, copy and pasting any of the four link types
Email & IM
Direct
HTML
into the "upload file from a url" part of manage attachments leads to upload error invalid file.
The size of my photo is 1.5MB, well under the 19.07 allowed for a .jpg.
The resolution of the photo is 3264 x 1836. Is the resolution numbered in the same units as the max width and max height in the manage attachments?
· Banned
Email & IM
Direct
HTML
use the IMG url
· Registered
Discussion Starter · #15 ·
[/URL][/IMG]
After painting the floor with several layers of latex primer and applying RAAMAudio vibration dampener. I didn't scrape up any of the old factory dampener that was still well adhered to the metal.
· Registered
Discussion Starter · #18 ·
[/URL][/IMG]
Here is where I hope I did right. The one piece mass loaded vinyl was unwieldy, so I cut it into smaller pieces. I was careful to always butt the edges against each other, or overlap. I finished by covering all the seams with wide Gorilla Tape.
1 - 20 of 29 Posts
