hey guys....new to the forum and been out of the car audio game for like fifteen years but i need a midlife hobby so i've decided to get back into it. I'm trying to replicate a setup that i had in the late 90's which was a Soundstream reference 500 running two jl audio 12w3's......that **** pounded so hard in my eclipse that i couldnt keep my rear view mirror up. so anyways after lots of searching i tracked down my holy grail and found an original oldschool reference 500 from this place in florida that is shipping as i write this. I'm still on the prowl for oldschool jl 12's but havent had much luck yet. In the mean time i'm just going to run a set of alpine e 12's off it but i'm very rusty and can't remember how i had it set up. i know i had it bridged but was hoping to get some advice on how to wire this up. the amp is stable to a .5 ohm so bridging is not an issue i think?? the alpines are svc 4 ohm and i want to power them as much as possible.don't even care if they blow up in a month as i will be replacing them soon. the reference is the only thing i'm concerned with. any help or advice would be much appreciated....thanks in advance!!!!!
You can bridge the 500 in high current mode and run a 2 Ohm load on it. If you wire your (2) 4 Ohm subs in parallel for a 2 Ohm load.
sorry if i sound dumb here but.......
so 2 positive speaker wires in the left+ of the amp
2 negative speaker wires in the right- of the amp
and then wire the speakers normal? 1 pos to pos, 1 neg to neg for each svc?
i thought i might have to do some weird speaker wiring sequence or something?
and then just flip to high current mode?
thanks!!!
