1 - 11 of 11 Posts
All I have is correlated. Looking for a source for uncorrelated of known food quality.
As a simple fix, could I just use correlated and turn the time alignment off to disrupt the mono sync?
I can't post links, but you can find them in the JL Audio website Help Center. If you google "JL Audio Help Center Audio Files" it should be one of the first results. Or you can navigate from the JL Audio Home Page >Support>Car Audio Support>Installation Techniques>Audio Files.
Here's the link to the JL Audio page with the test tones:
https://jlaudio.zendesk.com/hc/en-us/articles/235503327-Audio-Files
Although, I'm not really sure when you use stereo pink noise? I thought you were always supposed to use mono pink noise when measuring your system? When you the stereo pink noise be useful?
Thise jl files are not correct. They are both mono pink.
Uncorrelated pink does not image. It will not be centered on the dash like mono pink. Uncorrelated is not in phase on both channels.
I prefer to use both types for system wide measurements.
You're telling me that JL Audio can't correctly make a Stereo and a Mono pink noise file?? What makes you think that they are both mono (I'm really not sure how to tell)?
Uncorrelated is more than just stereo.
This is what uncorrelated pink noise sounds like vs mono.
https://youtu.be/7CMf3s3TSEE
https://youtu.be/6ZEFb6Zi3sI
You'll notice in video 1 if your time alignment is set, it will not have a center image. The noise appears to come from the left and right sides with no detectable center image.
In video 2 the noise has a strong center and is detached from the speakers.
Here you go - this archive contains both types and the stereo one sounds like the one in that YouTube video:
https://www.dynaudio.com/media/4031/pink-noises.zip
Thanks I'll check it out. Noise makes me nervous.
I spent years tuning with bad noise files.
The response wasn't even. Had as much as 6 db peaks and dips. That still has me aggravated.
I did eventually figure it out but I waste ton of time doing do.
Yeah I completely understand. You can waste a LOT of time doing this crap if the 'source' noise isn't correct - and there is no easy way to "confirm" if the noise is correct or not (that I know of). I guess you just have to trust the person you get it from? Would an oscilloscope help with that (not really sure)? I'm still tempted to get one of those small $60 oscilloscope's on Amazon, just to have around. Would be nice to use to confirm you're not clipping, etc... They actually get pretty good reviews - and some people even say that they used them to set amp gains.
https://www.amazon.com/dp/B01BMYS10S/ref=cm_sw_r_cp_taa_iWTuDbE614GXN
You can just put the noise in any music making program and see the consistency. Its very easy to do but I hadn't thought of it at the time.
1 - 11 of 11 Posts
