As to not waste your time with details I'll jump into the issue and what I tried so far.
Whining gets was worse when revving the engine. I understand it's called alternator whine.
Unplugging rca cables at the amp for front and rear speakers removes the whine.
Connecting my phone via Y cable to the amp eliminates the whine.
Both amps (for sub and speakers) grounded at the same chassis ground.
I tried 2 different headunits, no difference.
I tried powering one speaker directly from the headunit and not the amp - no noise.
Headunit is grounded into the metal bar under the dash.
I tried inline noise isolator filter between headunit and its power supply
No change at all
Axxess AX-ANR1000 Inline Power Noise Filter Axxess AX-ANR1000 Inline Power Noise Filter : Amazon.ca: Electronics
Tried 4 Farad power capacitor
Tried 3 rca noise isolator filters on amp side ams headunit side.
Connecting a filter just for rear or front rca cables reduces the whine. But plugging a noise isolator filter on both front and rear rca's, the noise is way worse than plugging only one filter.
I'm probably forgetting some stuff I tried.
I'm literally losing my mind over this and it's driving me crazy
My system is completely separate from stock audio.
One sub, 2 amps, 4 speakers and tweeters, 4 crossovers, headunit. All expensive quality components.
Power is through 0 gauge wire.
Tried grounding the amps on the battery negative instead of the body, no change. Rca cables are all high quality.
I tried powering one crossover directly from the headunit, just using wires from the pin plug, not rca.
This way there was no noise for that speaker and tweeters!
Tried grounding headunit rca female grounds directly to the headunit chassis.
I'm at a loss what could be the problem...
No change at all
