1 - 9 of 9 Posts
Hybrid Audio Clarus 6.5 compoent - $480
Midbass is brand new in box, one tweeter is used for demo, less than 5 hours of use. You can see the picture in my photobucket album.
AudioFrog GB15 - $300
Barely used, less than 5 hours of use. I bought this as a kit with AudioFrog GB60. I ended up using different tweeter.
CDT CL-42 - $180, brand new in box
Bought it for my gf's bmw, ended up with different direction. Good 4" component setup.
Coral Audio Component PRF165 and PRF25 tweeter - $100
https://www.rgsound.it/prf-165_coral-electronic-id-845.html and https://www.rgsound.it/prf-25_coral-electronic-id-843.html, in total, they retails for 210 Euro. Italian brand, good for entry level SQ component or louder SQ oriented. As you can see the magnet is huge for 6.5 midbass. Much better option than you regular "Sony/Alpine/Pioneer" speaker. This brand should be put on the same category with Hertz/Focal/Morel. The speakers will come with tweeter pods. Missing 1 passive crossover, if I can find it, it will come with both crossover. You can run it active, I do have CalCell amp listed on other thread.
Phoenix Gold RSD65cs - $80
Good working condition.
Pair of Digital Audio 6.5" midbass/subwoofer DAMD60 - $70 for the pair (2 pcs)
Big magnet, good for SQP or SPL. Specs: * Power Handling: 200 watts RMS * Frequency Response: 35Hz – 5kHz * 30oz. Strontium Magnet * Laminated Glass Fiber Composite/Pulp Cone * EPDM Rubber Surround * 2 Layer High-Temp ASV Voice Coil * 3 ohm Impedance * Sensitivity: 93 dB
Some new and some used. See above
See the description
Add $15 for shipping.
http://s602.photobucket.com/user/wilson_gau/library/Amp?sort=3&page=1
100% iTrader feedback here. Same username with 100% feedback in caraudioclassifieds.org, caraudio.com/forums, lxforums.com, chargerforums.com, forums.azbilliards.org.
Techical Specification: * Power Handling: 200 watts RMS * Frequency Response: 35Hz – 5kHz * 30oz. Strontium Magnet * Laminated Glass Fiber Composite/Pulp Cone * EPDM Rubber Surround * 2 Layer High-Temp ASV Voice Coil * 3 ohm Impedance * Sensitivity: 93 dB
1 - 9 of 9 Posts
