My bad im still waking up. And yes my OP looks like a 3rd grader wr5ote it.TLDR...what do you need?
1. you can run channels 1 and 2 at 2ohms. So yes you can wire the two sets of front speakers together and use channels 1 and 2 for that. Leaving you the ability to bridge channels 3 and 4 to power your subwoofer. It just needs to be a 4 ohm if you bridge channels 3 and 4.Lol yeah I thought I should add one of those. Would it work to wire 2 sets of 4 ohm speakers (focal flax evo ps 165fe with a crossover, JL c2 650 with no crossover (built in I guess)) to one channel, and a sub (some MTX sub a friend is giving me) to the other channel on my RF 600/4 amp. Amp is stable at 4/2 ohms. OR , would it be better to just run the 3 way and sub, its in a single cab 2012 F-150.
SECOND QUESTION, I have the 6x9's in a crap box I made with some 3/8 scrap MDF one day at work, wanted them mounted on the sides behind the seat, pretty sure the side impact airbag goes there and don't want to cut into the panel, so I'd rather keep them in boxes as its a work truck (i Own it) and like the option to easily remove the 6x9's if I need to.
I'm thinking I misspained, current setup-Focal 3 ways (with external crossover) , JL 3way 6x9's(no crossover) both sets 4 ohm. RF t600/4, 100 per channel at 4 ohms, 150 at 2. Can I run the speakers off the front channel and the sub off the rear channel? I thought to bridge it I would have to plug the positive into the positive from the front channel, and neg to the rear negative channel? Sorry I'm a wood man not a sparky, know just enough to get myself into trouble.1.
2. not sure what your question is on the 6x9's.
Its 4 channels....and you are not briding it to 2 channels, you would leave channels 1 and 2 unbridged and running all your speakers at 2 ohm total. Then you would be bridging channels 3 and 4 to make 1 channel for the sub.I'm thinking I misspained, current setup-Focal 3 ways (with external crossover) , JL 3way 6x9's(no crossover) both sets 4 ohm. RF t600/4, 100 per channel at 4 ohms, 150 at 2. Can I run the speakers off the front channel and the sub off the rear channel? I thought to bridge it I would have to plug the positive into the positive from the front channel, and neg to the rear negative channel?
Ok cool that is what I thought, I just wanted to make sure there would be no issue with the focals being a 3 way set going from a crossover. So I can go from channels 1-2 to the crossover and the 6x9's, and 3-4 to the sub.Its 4 channels....and you are not briding it to 2 channels, you would leave channels 1 and 2 unbridged and running all your speakers at 2 ohm total. Then you would be bridging channels 3 and 4 to make 1 channel for the sub.
View attachment 317539 View attachment 317539
yup. No idea how it will sound, but yes you can do it.Ok cool that is what I thought, I just wanted to make sure there would be no issue with the focals being a 3 way set going from a crossover. So I can go from channels 1-2 to the crossover and the 6x9's, and 3-4 to the sub.
It sounds pretty decent actually. Ended up one of the subs was bad so now I have a passive box lol. I am gonna make (or maybe just be lazy and buy) a truck box and new sub after the new year and....ugh.....taxes.... Sometimes I love being 1099, sometimes the government makes me hate it.yup. No idea how it will sound, but yes you can do it.
